DeathPrincess
- May 15, 2010
It was the first game to kill the first dedicated GPU I ever had. (Rage 128) on windows98
Then I got a something else (not ati, it probably began with n or 3) and it ran fine (it ran fine before, but I had decent draw distance, and no ghostly white worlds) on xp.
I still have it on disk, but no code, and I can't be bothered to find a code for it, so I got the steam version the other day because of the game remake thread...and now it doesn't run.
I can run the game fine, but as soon as any creatures are summoned, after the first, it hangs for a second, then just lags as if it is running at 0.1fps and runs in slow motion. Also several of the creatures just turn up invisible.
The specifications are (I have)
OS: Windows (7 ult)
Processor: Pentium 300Mhz (non pentium i7 2800/4000+mh/z
Memory: 64MB (6144mb but sacrifice will only see 1024)
Graphics: DirectX (GTX 470, i'm not going to try SLi anything with this...nor need to, unless I can find some voodoos)
DirectX®: 7 (11)
Hard Drive: 650MB (much more obviously)
Sound: DirectSound (realtekHD brand onboard, spidif to external, m-audio soundcard blah blah not sure if they have DirectSound, but sound is no problem)
Lowest settings, and higest settings. No change.
Both modes at launch (direct 3d HAL/direct 3d T&L HAL)
Various compatability settings (it comes from stream with win2000)
Overclocked and no overclock CPU
Changing thing "extentions limit" parameter on the nvidia control panel
Still the same, just with various levels of old school.
I know it's sold on that-Games-site-which-pretended-tO-close-down-with-the-monks-and-pissed-off-people_Greatly place that apparently works on windows 7 64bit. But I have read people have problems with that version too, so probably they did nothing to it. It has no DRM outside of a key also.
The steam version appears to just be the fully patched to 3rd version of sacrifice with the serial preloaded, and the noCD style registry fix.
It's apparently a nvidia issue because of no longer including something. But noone seems to know anything and i've read it not working on AMD type cards too... The 64bit might be an issue, but again 32/64 people have the same problem.
Has anyone found a way to get this to work with a similar (nvidia GPU/64bit) system?
Or has any other ideas to get this to run? I really want to give in to the nostalgia beast...
OS: Windows (7 ult)
DirectX®: 7 (11)
