Ryzen PC with 1650 Super
undertaker2k8
Dunno why I got it but it's Fri night and this seems like a good deal for 425 with the coupon attached, given how just the 'cards' are going for 300+...the seller is basically walmart's ebay arm so no issues with returns.
Not sure what I will do with it lol but hoping someone who needs it can snag the 4 or so remaining units....
https://www.ebay.com/itm/HP-TG01-00...-/114541082205?_trksid=p2349624.m46890.l49292
Update: I canceled my order, could have made some money parting it out on the bay but too much time and effort, really good deal for anyone that needs it though.
bufodr_T
That was sold out but I picked up the i7 8700 16gb 256gb 2tb 1060 cyberpower pc for $550
SirKronan
I bought one of these. Has an actual 400w platinum power supply in it. It's able to run and fit a 3070 FE in it. Also, mine came with a 3600 instead of the advertised 3500. Bluetooth + WiFi + SFF .... it's a mean little system after my mods. :D
undertaker2k8
Finally ordered one myself lol, was gonna fleabay my 3060 but am thinking will use it for mining on this since the limit is now breached and fleabay the 1650 instead.
I could technically put the 3060 in my primary rig as well but don't want to put more heat into it ...
undertaker2k8
Got it today sweet little rig, fits my 3060 pretty good and the 400w psu comes with an 8 pin GPU connector. Too bad mine came with only a 3500 and not a 3600 like some got. Total was 470 with tax before whatever the 1650 sells for...
With the 470.05 driver NH is giving a nice 47 Mh/s rate.
undertaker2k8
Anyone tested the max GPU card length/height that will fit this? Skeptical my 3070 KO will fit and don't want to open the box unless I know for sure, thanks.
undertaker2k8
So measured this today, it can fit upto a 10.7 inch x 5.2 inch x 2.75 slot card. Unfortunately the 3070 KO may end up being just a bit too big at 10.8 long ( there is a slightly longer recess just below the top of the side so may be possible to angle it in...) otherwise will have to do with the 3060 xc in this one. The little case with 5x usb front ports including usb-c is just too nice to swap out for a 10 Mh/s increase :)
