Ryzen Master no go!
funkydmunky
Recently updated my archaic 1700X to a 5700X. I want to play around with mt B-Die so I decided to open up my Ryzen Master to get some quick details (voltage etc...) It wouldn't run and said it was incompatible. Ya I thought, old CPU so needs an upgrade. So... did an uninstall and an install of the latest version.
To my surprise I get this message. "Ryzen Master unable to initialize. Kindly reinstall". I've tried. Anyone know of this? I don't need RM but I always used it as a quick check when I didn't want to go to BIOS.
See if there's something in your UEFI BIOS that's making it incompatible. Are you overclocking?
If not that, then you might need to reinstall your operating system.
I had this issue on a few rigs. There is something registry wise to remove that will fix you.
Open regedit and delete the directory-X represents whatever number(could be v13/v14).After deleted then Ryzen Master will start without reinstall.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\AMDRyzenMasterDriverV1X
Edit: credit to gerardfraser
