Ryzen "B2" Stepping a False Rumor (apparently)
Yeah, I cleaned both surfaces with IPA before applying the AS5, and the cure time is why I'm going to give it a few days before considering removing it again. I've not actually played with Ryzen Master at all yet, nor have I even checked to see if ASRock has any sort of utility for setting voltages like ASUS has. I'm old-school and do everything through the BIOS. I also dimly remember reading that Ryzen Master had some teething issues early on. I've been doing the blend tests, so I should probably try isolating the CPU and running a few tests. That's likely what I'll be doing over the long weekend.
From my experience, Ryzen Master is worthless, and isn't anywhere near as nice as OverDrive was since it only provides you the ability to change 4 voltages (CPU, NB, DRAM, DRAM Vref), CPU multiplier, and primary memory timings. Of which, changes to the DRAM require a restart (pretty certain the NB voltage does, too). It also lets you disable cores, but that too requires a restart and at that point it becomes "who cares?". I was extremely let down by what it ended up being.
Now, K17TK is a nice program, as it lets you modify the PStates, which MSI has failed to provide us in their BIOSes, we also lack the Voltage Offset, so any changes to that promptly eliminate the Cool n Quiet automatic voltage adjustment :\
Only problem about K17TK is it causes Win10 (and no doubt 8 as well) to rear it's ugly Real Time Clock issue's head, and while overall that's no big deal once you're done with benchmarking when everything is dialed in, but if not... it skews your results in some programs (like AIDA64). For example my L1 cache speeds for Read and Copy at 3.8GHz set from Windows report as 1050GB/s... whereas it should only report as like ~940GB/s (which it does, when set via BIOS or set via Ryzen Master).
