- Dec 19, 2005
Why? We new this was going to be the case based on the 3900X
i didn't know
been saving up for a 3950X, need (shallow desire) 5 GHz All Core from factory![]()
heh, guess i lost perspective in the hype and my expectations got too highYou can't get that anywhere, Intel included, so how the hell could you possibly expect AMD to do it on a 16-core part?
Was never even a possibility
If AMD could do 5.0GHz on all cores, it would. It's simply not possible on the Zen 2 architecture and process node using ambient cooling. Why would you have thought otherwise? We knew there was no chance in hell of hitting clocks like that based on existing Ryzen 3000 series processors. 4.1GHz-4.3GHz is the wall for these cores. Adding more in the same package doesn't help. It makes it more difficult to achieve.
Anyone who held out hope for more was either uninformed on the subject or delusional.
my biggest problem with this is that it has to be pushed hard with water to achieve all core 4.3... i'm not into overclocking myself so this is tough![]()
Wait is 4.3 on all 16 cores supposed to be disappointing ?
Still .... if we can get 4.3 all core on a 16 core part these are going to be hard to find.Intels Cascade part is going to be 2 cores short... 600mhz short on boost... lack PCI 4... and still cost more even with the massive drops. It sounds like it will also be way short on all core overclock numbers unless Intel has magic 14nm+++++ process. lol
yah, i want to see 5 all core from factory and stock
^^that's your problem. you expect it to do something never promised.my expectations
result=I'd like to see a pterodactyl making sweet love to a grizzly bear.
Enjoy your brand new Intel 9900KS, then. It's the only CPU that will have this capability.yah, i want to see 5 all core from factory and stock
I'm waiting for 10ghz netburst. I'll upgrade then.
This isn't tech news.
Cause THIS!:You can't get that anywhere, Intel included, so how the hell could you possibly expect AMD to do it on a 16-core part?
