Nebell
- Jul 20, 2015
Where were you when the A64 reigned supreme during the dark days of the Pentium 4?
I think I still had my K6-2 back then.
You're comparing 8700k to 2600x right with the same core count? I mean unless I am blind...
https://www.techspot.com/article/1616-4ghz-ryzen-2nd-gen-vs-core-8th-gen/page3.html
Also I am with DuronBurgerMan, you're making me feel like Shittai or Wrongrga.. I would be rocking AMD right now no doubt if these new chips were out at the same time the 8700K was released.
You are damn straight I was looking at the 2700x numbers, because the 2700x has a higher IPC than the 2600x, which is what this whole argument is about. Also, the ONLY game that utilizes more than 4 cores / 8 threads at once is ashes, the others do not, which means the extra cores mean nothing when it comes to the IPC gaming performance.
IF you go look at all the benchmarks with the 9700K, you will see that the 8700k beats it in some games, and they have identical IPC, but yet, the 9700k has more cores. Go figure.
LOL!!
You are damn straight I was looking at the 2700x numbers, because the 2700x has a higher IPC than the 2600x, which is what this whole argument is about. Also, the ONLY game that utilizes more than 4 cores / 8 threads at once is ashes, the others do not, which means the extra cores mean nothing when it comes to the IPC gaming performance. I also ignored the 2600x results because most sites do not show the 2600x under performing in comparison to the 2700x with the performance between the two having only a couple fps in most games which is due to the IPC difference (and that is at stock speeds) . This article was also published 1 week after the release of the Zen+, using a motherboard that had temperature and throttling issues that was corrected with a later bios update. You also have to take into account for the memory settings. Yes they used the Exreme memory profiles, which is an INTEL specification, and AMD Ryzen Motherboards do not translate the profiles accurately, which is why it is recommended to manually input all the memory settings to get the proper and optimal performance. Also the Asrock X470 on release had issues with XMS profiles and not running at full speeds, it wasn't really an issue per say, but was related to XMP profile translations and setting that had to be manually set. That is why you need to take all benchmarks into account, not just the gaming to see that there is only a 2% to 5% in IPC difference between the Zen+ and Intel's offering.
If you really want to get into the nuts and bolts of things, Was the 2600x getting throttled due to the overclocking as it is a lower binned chip than the 2700x? Hence why it's default speeds are lower (seems like it was being throttled since there is such a large margin between the 2700x and the 2600x), which there shouldn't be in almost all games since they do not utilize more than 4 cores. IF you go look at all the benchmarks with the 9700K, you will see that the 8700k beats it in some games, and they have identical IPC, but yet, the 9700k has more cores. Go figure.
Point is, there are so many influences when it comes to gaming benchmarks, that they cannot be used as a indication of IPC performance.
Some of those specs. LOL.
Launch at CES. LOL.
Someone got one from nowhere and reviewed it. LOL.
AMD IPC is 3--5% behind Intel. LOL
LOL!!
Does the 1800x have a higher IPC than the 1600x also? Seems like more than one game were using the extra cores. Also why is there a difference in IPC between 2700x and 2600x besides the L2 cache that shows such a huge boost for the 2700x?
My Ryzen 1600 system when it came out running B-die memory worked fine with XMP enabled out of the box, CPU was soldered and ran super cool compared to my 8700K system. I don't see how a legit site like techspot would have any of the overheating/throttling issues you're claiming .. unless you meant some of the intel chips were throttling if they weren't delidded? lol
9700K vs. 8700K is apples and oranges... 8 cores no HT vs 6 core / 12 threads... ?
Point is I am just copy and pasting whatever the article said and today I learned the 2700x has a way faster IPC than the 2600x.
Is that why my 2700x sits with all cores at a tad under 4.1 when playing modern games? Older games run with ~4 cores boosted higher and the other cores with a lighter load in the ~3.5 range.
<blablabla> Also, old games vs newer games are handled differently by the OS and how it allocates CPU usage.
No -- please explain how the OS is supposed to differentiate between an "old" and "new" game? All things equal, the OS treats a game just like any other process.
First, if you go look at techspots review of the 2600x and 2700x, their numbers are different then what they show in IPC/4.0Ghz comparison, in some cases they have both the 2700x and 2600x overclocked even higher yet getting worse performance numbers, and they are getting better performance at stock speeds in some games, which shows there is to much fluctuation in gaming benchmarks to make a legitimate determination (of course they are also all done 1 week after release of the Zen+). As for the 1800x, yes it has higher IPC than the 1600x. As for your memory running right out of the box, that was't the case for many people, there where some lucky ones, but not many. The first generation of Ryzen had issues with ram speeds for months after release, and in some cases still do. Also, showing running at 3200Mhz does not mean it is running at the same optimal settings as it does in an Intel board due to missing settings that the XMP do not have that are in the AMD specification, again, why it is recommended to set all ram settings manually.
As for the 9700k having NO HT, you are correct, I actually meant the 9900k.. sorry.
How about a link to the benchmarks? And also, according to those 4.0Ghz comparison graphs, you're saying the 2700x has a 10% or so IPC advantage over the 2600x looking at those numbers and those higher values has nothing to do with the 2700x having more cores?
Since you are to lazy to look for them :
https://www.techspot.com/review/1613-amd-ryzen-2700x-2600x/page3.html
Now go read what i said, and the reason i ignored the 2600x results, as they are not accurate, as the reveiw and benchmarks i just linked you show both the 2600x and the 2700x very close with the 2700x being slightly ahead of the 2600x due to the better ipc, and nothing to do with core count. This is at stock speeds (2600x is slower), 4.1 Ghz and 4.2 Ghz over clocked. But yet, for some reason, the 2600x all of a sudden drops significantly in the 4Ghz comparison vs the 2700x. And both articles are by the same place. Hmm. Yea!!
The only benchmark that shows any variation is the Assassin's Creed Ultra setting one and they mentioned GPU limited many times which is why the 2700x which was running 100Mhz higher than the 2600x at stock or overclocked has a slight lead.
Oh in case you want to take the GPU out of the equation even more, they conveniently have the BFV CPU benchmark using a 2080 Ti! Which shows once again a significant performance drop for the 2600X compared to the 2700X. Oh and if you want to compare the IPC with Intel since this isn't a clock-for-clock article, you can use the i5 8400 in this link which only boosts to 4.0Ghz which is 200-300Mhz lower than the Ryzen offerings.
https://www.techspot.com/review/1754-battlefield-5-cpu-multiplayer-bench/
You keep moving the goal posts. There is only a 3 to 5% difference in IPC between AMD and Intel at identcal clock speeds. I already showed you one discrepency, i was also showing why you look at the 2700x when comparing IPC between AMD and Intel.
BTW the GPU bottle neck was for the 8700k, it was not bottlenecking the 2600x or the 2700x. As for your 2080ti reference, you will get a performance drop, as you have 2 extra cores that the 2080ti can offload some of it's work to on the 2700x, which all GPU's do, this is not the game utilizing the extra cores, but a monster GPU. Being cpu limited vs the gpu is no demonstration of IPC.
Moving the goal post? I posted some benchmarks and you just change the subject again. So the i5 8400 which is running at a clock deficit is beating the 2700x yet you claim 3-5% difference in IPC?
I mean I am not the one making stuff up lol
And now you're claiming the 2700x has two extra cores the GPU can offload work to yet you claim earlier the 2700x is beating the 2600x not because of the extra cores but because it has a lot higher IPC... okay... LOL
Here go read:
https://www.quora.com/How-does-the-graphics-card-work-with-the-cpu
First, i have already shown you the discrepancies with techspot. I never moved the goal posts but you don't want to use cinebench to determine single core performance, which directly measure IPC, and only want to use game performance. I explained why you use the 2700x for determining IPC between AMD and Intel, I used references using identical clock speeds to demonstrate it using only games, but you focused on the 2600x... Which is your mistake.
Now the i5 8400 is the same generation as the 8700k, which means it has the same IPC as the 8700k (as this is how Intel rolls, as the main difference between there chips of the same generation is core count, clock speed and HT), it boosts all cores to 3.8 Ghz, the 2700x, depending on cooling and tempurature will boost all cores to 3.9 to 4.1 Ghz.. if it is the stock cooler, most likely it boosts to 3.9 to 4Ghz in Battlefield one (dependent on the correct settings in bios) if the settings are wrong, or not enabled. no boost, just 3.7 Ghz. In otherwords there is really no clock deficit between the i5 8400 and the 2700x. One had HT or equivelent, one does not. So the 7fps (5%) difference is due to IPC as we really don't know to what extent HT effects BF1. That is 5% in one game, but thank you for picking out an example that supports that there is only a 5% differnce between AMD and Intel.
Not to mention, one game does not prove anything, specially when all CPUs are not running at identical speeds.
What's funny, in your desperate attempt to prove me wrong, you ignored the very fact that the 9900k is only 15% faster than the 2700x.. yet it runs nearly 25% higher clock speed than the 2700x, which says what about it's IPC in comparison to the 2700x to only be ahead by 15%.
Yeah and it also has two extra cores which gives it a very generous boost over the 2600x, wouldn't it be more fair to compare the 8400 to 2600x since the monster GPU in this game is using the extra two cores of the 2700x? Or is it just the superior IPC of the 2700x giving it the lead or is the 2600x still throttling due to these benchmarks being run right after Ryzen release (The article came out in November 2018).
Yup, it's just one game and doesn't prove anything at all, just the gap is bigger than 3-5% no? lol
Do you fail to recognize the 2700x is handily beating the 2600x because it has two more cores?
Nice edits btw
Uh, yes, it is how older games passes on cpu calls to the OS, vs modern games. Hence why some older games don't work with new OS's as they try to use pathways or cpu calls that are no longer supported in a new OS, as well as calls to the gpu If that wasn't the case, then every game would utilize all cores, and it wouldn't be game specific, as all modern OS support multi cores, if what you say is true and the OS treats all applications the same. Actually most modern games have direct access to the cpu, but the OS still determines the "cpu time", meaning it still controls how many cpu cycles each application running gets, with the main application (games) getting the majority. The OS also distrubutes the work load to each core. That is why you see the usage bounce around on various cores. Specially more so in Windows 10 due to how it distributes tbe work load via it's schedular.
Sorry, i am on my phone, so posting, corrections are a little more difficult and time consuming.
The problem is, you fail to understand that it not the game that is creating the difference. The game is not using the extra cores. The 2080ti is throwing calculations at the 2600x that it can't handle fast enough, where as the 2700x has the extra cores and higher IPC to offload the workload of the 2080ti vs the 2600x. You can't deliberately bottleneck a cpu and then start saying it underperforms.
Okay, so why did you conclude 8400 vs 2700x was a fair comparison and said it proves your 5% argument then when in fact the 2700x has two more cores to work with as well as threads?
Hello, because we are talking about IPC. The i5 8400 does not have the issues the 2600x because it has 6% to 7% more IPC than the 2600x (remember the 2700x has better IPC than the 2600x), and also boosts higher on all cores than the 2600x, giving it's ability to handle the 2080ti much better. Each core on the i5 8400 has a higher IPC, multiply that by 6.. do the math. the 2700x is 5% lower in IPC, per CORE, do the math, (keep in mind the game is not utilizing all the cores on the 2700x, all though you keep implying that it does) You also disregarded my comment about threads. We do not know how battlefield 1 handles threads, as MOST games do not utilize threads. Hence, why it is recommended if you get stuttering or slow down in games to DISABLE HT. you lose NO gaming performance in 99% of the games out there when it is disabled, but can actually gain performance. That is why the I5 has been recommended as one of the top gaming CPU's if that is all you do with your machine, because HT has little or no impact on gaming.
You keep talking about the extra cores when gaming.. THE GAME does not use all the cores. The 2 extra cores are being utilized by the GPU's calculations and back ground applications, not the game. You are so focused on the cores, that most games don't use. (research it)..
I am not making things up. You just lack the knowledge to understand and keep fixating on those 2 extra cores that are not being used by the game, all while igoring rhe IPC differences.All I see is you making up crap in order to justify comparing the 2700X to the i5 8400, which the 8400 wins too mind you with a 100mhz worst case scenario deficit with two less cores.
Oh and the 7600K with no HT gets murdered in those charts.
Happy Holidays!
Happy Holidays!
