LanceDiamond
- Oct 11, 2005
I am familiar with overclocking in general - not asking a very basic "raise voltage, test, repeat" type question here.
I am running a Q6600 at 3.2 currently. Prime95 stable for > 24 hours. It *seems* to run fine at 3.6 also but Prime95 croaks after about 7ish hours and I strongly suspect it's heat related rather than Mhz related. Problem is, I can't confirm it not being Mhz related by going beyond 3.6 - my memory just flat refuses to cooperate with even 410Mhz FSB. I have 4gb AData fairly cheap memory.
My question is really just a general one: If you're running your Q6600 at 3.6, did you test beyond 3.6 and find that 3.6 was the best stable you could do or is 3.6 as high as you could boot and it seems (or in fact is) perfectly stable there?
I know I could invest in slightly better memory but I don't know that it is worth it, other than curiosity. I am *really* curious what the max Mhz on my Q6600 is and without better memory I can't find out.
