SevenWords
- Sep 8, 2006
I just started leak testing on my first W/C setup and my pump is considerably louder than I thought it would be. The first pump I got with my system turned out to be dead, and since the bracket was already mounted I bought another pump part without the bracket and replaced the dead one. It pumps fine now, but is pretty loud and also makes my reservoir bubble quite a bit because its so powerful. I was wondering if I would damage the pump by running it at 7v instead of 12v? I run all my fans (Yate Loons) like this and they're silent, so I was hoping it would help the pump noise and the turbulence in the res.
