RPG noob seeks tutor
I'll also say that the Dwarf noble's origin story was one of the best beginning stories I've seen in a long long time.
I recommend that if you start DA:O, you pick a warrior to start out with since they have an easy learning curve to use and whatnot.
Which character would Soap McTavish choose if he were starting the game??
DA:O is great but its not everyone's cup of tea, I'm going on a mini vacation starting tonight and I think I'm gonna have withdrawals from being away from this game...
I personally started a mage first, but after seeing how my 2 best friends both already had elf mages, I decided to make a dwarf noble Rogue, and so far i have almost 10 hours into the game and just finished the battle for Redcliffe. Rogue is fairly easy to pick up and play, but it requires a little finesse because you need to move your rogue BEHIND your enemies so you can backstab them for high damage.
I don't think any of the classes are hard to play as long as you understand their playstyle. Mage is definitely fun to play as long as you pick up at least one heal spell, if you use your mage to do nothing but CC/heal then it's probably going to be an easy game to play through i'd imagine, given how powerful CC is in this game. There's very few situations I can foresee a mage dying in (at least up to where i am in the game).
But as long as you learn how to manage your party properly, the game shouldn't be all that hard.
I'm pretty sure this game isn't noob friendly, it's not meant to be, but it doesn't take a genius to figure out either. It has an average learning curve for the experienced gamer. After you go thru the first few hours of the game, you could probably start over and do way better and know what to do on your second play through. At first it felt a little confusing, but by the time I had played through the mage's backstory, I felt comfortable enough with the game to try another backstory, the dwarf noble.
Perhaps your experience might be the same. Just dive in and have fun and just ask any questions you have here
Be prepared to play for 6 hours in a row or more. Sure, you'll sit down thinking "I'll just finish up this one quest, save and quit".
Just make sure to check your clock and don't be late for work in the morning. "I was playing DA:O until 4am" doesn't count as a valid excuse. :D
Feel free to shoot me any questions, I'll try to field them. For my first runthrough I've been playing as a chaotic evil rogue.
Morrigan loves me (Massive Magic Bonus), Sten likes my no bullshit attitude although he doesn't appreciate my pickpocketing abilities. Alistar and Wynne, on the other hand, I'm sure are conspiring against me. There are so many characters to interact with, it's just awesome. You'll miss alot if you don't spend time conversing with them all.
The barking contest between the dog and Sten alone is worth the price of admission. :D
As you play, pay attention to the help boxes that show on the bottom right corner of the screen. Read them all and it will help some.
A few basic pointers:
-Get cone of cold (third spell in the cold line) ASAP. If you aren't playing as a mage, have Morrigan get this spell, as well as heal, as soon as you can.
-Use TAB to view all interactive objects. You'll miss a lot of stuff if you don't. I spend most of my time running around holding this key down... well, I remapped it to caps lock since that's easier to press while moving around with WASD.
-I also recommend holding right click to allow free camera movement. I actually spent the first 20 hours playing this game using just WASD, with A and D as the only method of turning the camera. I literally smacked myself when I discovered I could just hold down right click to free look and WASD to move normally.
-Play around with the Tactics interface...you can automate a lot of the tedious stuff with this. For example, the first line on all my party members is Self: Health < 50% --> Use item: health poultice (least powerful), and they all have lines to activate various abilities, and attack the target of the currently controlled character.
To everyone my continued thanks for all the tips. Have been and continue to be reading them all. Spent all last night (till very late) trying to install the game.
Kept getting - - {INSTALLATION FAILED DATA ERROR}.
Finally figured out it was my CPU overclock after uncountable failed attempts. Backed it down a bit and the game installed just fine. My OC is both prime and OCCT stable but the Dragon Age installation DVD did NOT like it.
Ok, lesson learned. Decided to take today off to add to this long holiday weekend to tackle this game. Began today by downloading the Shale and Blood Armor content. All was well. Then downloaded and applied the 1.01b patch per advice of poster here. That bricked the game. Would not launch. Spent all day until now trying to fix it. Finally did. Very frustrating and time consuming, but, it's finally up and running. Whole day gone. Beginning to read the manual now.
honestly, from your background oblivion would have been the place to go. I converted a friend of mine who was always into shooters and could never get into rpgs. Gave him oblivion, then he picked up fallout, now he bounces between DAO, some other random rpgs, and WoW
Trust us, you'll be hooked on RPG's once you fire up Oblivion and join the Dark Brotherhood and complete their questline . . . . .
I remember my first RPG, I think it was either Diablo, or Final Fantasy 6. Damn good memories.
To "CLIMBER" and "PRINCESS FROSTY".......... Would you please weigh in on this question. I wish to learn. Want to get off to a good start.
If you're playing a mage like I am I found that going the elemental tree early on is a good tactic, the fire spells have good damage, the Frost tree has good CC (Crowd control) which isn't needed as much early on but later is essential for evening the numbers in fights.
The only 2 absolutes I would recommend early are Freeze and Heal, they're very helpful.
All the spells are good to be honest, I wouldn't go as far as to say it's impossible to pick wrong but basically if you make sure you get a good balance of spell types which include:
  • Pure damage
  • Crowd control
  • Buffs (spells that improve party members like the flame weapons)
Too many of one and not enough of one make fights harder overall, a good balance between these types of spells is what makes a good build.
As you progress as a mage find out what problems you have in combat. Is there too many people at once then get some more CC, if you aren't doing enough damage then get some more damage spells or buffs for party members to improve their damage. If your mage is constantly getting attacked first instead of your tank (big guy in armour designed to take lots of damage) then you're doing a bit too much direct damage, dial that back a bit and focus on a few non-damage spells.
Yeah, Oblivion can only be called an RPG is a very loose sense of the word, this really just shows us how much consolization has leaked onto the PC platform, Dragon Age is a refreshing comeback of traditional PC gaming that's not dumbed down like a lot of other multiplatform games today. On a related note, Deus Ex 3 will be PC only, how good is that!
Ok, couldn't make up my mind so I started as a human warrior. (Gives me a tenuous grasp on reality.)
After FIRST person shooters this third person thing is proving very difficult.
This thread reminds me of a personal want-add. Desperately seeking a companion to spend romantic nights with. Me: single male with computer. You: RPG enthusiast with extensive knowledge of leveling and party mechanics. Can we hook up? Hugs and kisses.
Just take your time, go through the origin story
then try another character's origin story till you're playing a class you like playing.
your 2nd or 3rd time re-doing your character, you'll have the hang of it and you'll be prepared to finish the game with your chosen character.
that's what I did
made a mage first
then a dwarf noble rogue
then a dwarf commoner warrior
decided to play out the dwarf noble rogue's story, and here i am, 26 hours into the game
you'll find yourself doing something along those lines.
Just find your comfort zone and roll with it
Good luck in later levels if you continue to play the game! One thing about this game that differs from some rpg is on battles you will want to use common sense on how to fight the baddies otherwise you will have difficulty and be frustrated.
Oh and a HUGE HUGE HUGEEEEEEEE advice for you if you are playing the quest-line involving the dwarf area. ONLY I repeat ONLY do ONE SIDE of the MAIN QUEST LINE with the dwarf where you have to CHOOSE a side with the dwarves. There is a terrible bug in this game that Bioware has not fixed where it allows you to do BOTH quest line and if you do you will be stucked in the game and cannot proceed.
This has happened to me and many countless others. I had to restart the game after 60 hours of gameplay!!!!!!!!! So pay attention when you get to that part.
A HUGE thank you for that. Would really suck to get 60 hrs. in and need to start over. Thanks again.
You can't simply reload a save prior to making the choice(s) and then go forward from there?
Then you'd only lose a few hours at most I'd suspect.
If they're like me, on PC, >99% of my saves has been quick saves, only 1 standard save. Definitely do more standard saves now. Thanks for the info on the bug, villain71.
explain how Oblivion isn't a RPG???
Your enemies scale with your character, rather than your character advancing past them on a fixed scale. As such, your character doesn't truly advance -- all of the leveling up and refining skills becomes something of a sham, at least with respect to combat.
It's still a "role playing game", but it doesn't use a traditional path in terms of character advancement (which is essentially fake character advancement). So, Oblivion is more of a complex hack-and-slash with skill sets than an RPG.
I think Morrowind would be easier for him to get hooked on, I know thats how it was for me.
Yep. Morrowind is kind of a hybrid. It's dumbed down from some of Bethesda's older games like Daggerfall, but it's still a true CRPG at its core.
This SUCKS!!! I'm trying to get laid but it turns out I don't understand women any better in a damn game than I do in the real world. Got Morrigan and have been trying ever since I got her to get her approval rating up high enough to get me laid. Gave her all my gifts; even bought a necklace from a trader and gave it to her. Her approval was headed up nicely. Got Leliana but have no gifts left. Now it seems every decision I make pisses Morrigan off!
Women!!!!
Yes, this is fun. Combat, making proper use of the tactics menu, seems like playing a game of chess where a FPS is kind of like picking a bar fight. Different, of course but I'm starting to get into it.
I was gunna say to the OP, just aim and shoot, but me thinks he means another type of RPG :|
after reading your OM.
I would say DA is probally going to be too much for you. I would also stay away from gothic or risen.
Mass effect, Vampire Blood lines, i think these would be better for you.
if you want to start even slower, i would suggest hybrid games like, oblivion, fallout 3 and deus ex.
Women!!!!
You don't want her approval very high. She's into flings, not long term romances.
Don't get her approval above 50 and be very careful about what you choose in normal conversations with her. I could PM you a sorta step by step if you really want it. :D
She's pretty hot. Think I'd only be interested in a fling though as she's also a bit of a bitch.:cool:
Not that bad, at least not yet. I'll try for it myself. Gonna take more than dinner and a movie I think.:cool:
Drop me a PM if you get stuck. She can be a pain to get into bed.
I only worried about it to get all the achievements done, which now on my 3rd playthrough I have done. ;)
