- Jun 29, 2004
wayne said:it gets airflow if theres ample input and output... im guessing that fan is input so if you need output... just drill some holes around it for airflow... it doesnt always just cool the parts, it removes the air around it that becomes hot when the things heat up
Well the router has alot of open spots on the side and I can feel the warm air being pushed out of it, so I guess it works. Before my router was hot when you touched it and after the mod its room temp.
