VanGoghComplex
- Apr 5, 2016
So, with regular g1/4 90 or 45 compression fittings, do you have any control over the direction they point? My small GPU loop will have some funky angles to it.
I guess the question is: do you buy rotary fittings so that they're moveable after install, or do you buy them because they're moveable at all?
I don't want to pay 30% more per fitting if it's not needed.
