I am using the case below and had a few questions about fan placement/direction. I have a 92mm setup as exhaust at the back, a 120mm in front bottom right behind the lights as intake, 120mm on the lower side port setup as exhaust and a small 80mm in the lower two 5" bays as intake all hooked up to a fan controller. My main question is if the lower side 120mm should be set up as intake or exhaust? I typically leave it off unless I am gaming since my video card is right there. The top of the fan is right around the edge of the card. Thanks!
