Gatecrasher3000
- Mar 18, 2013
Very interesting handheld, love to see the competition.
Knowing Asus it will be. Got that ROG premium you have to pay up for!!Not really. Don't care for these devices. Guarantee this is going gto be over $1k.
The CPU will already be holding back a higher end GPU I bet. It is only a 30w CPU at most I believe.Not really feeling it - I also agree that this thing will likely be priced above $1k due to its specs. The external GPU support is cool, but I wonder how long that sort of setup would last before the CPU starts holding the GPU back.
What they should've done: use the custom SOC, pair it with a OLED (leave it at whatever resolution they can source for the cheapest, 720p or 1080p), remove the superfluous bits to save cost (glowing sticks, high refresh rates), add SteamOS support and price it in the ballpark of a Steam Deck at a slight premium.
That type of config I can see selling well for them, and then later on, when they've built some goodwill with the community, they can release their ROG version with the superfluous bits back on.
With a Z1 Extreme, if you’re playing at 720p with low settings like you might comfortably do on a seven-inch handheld, AMD claims you can cross the 60fps line for games as demanding as Red Dead Redemption 2 and more than double that for Forza Horizon 4 — all upscaled to 1080p with AMD’s Radeon Super Resolution.
With a Z1, you lose the edge in some of the most demanding games, but the numbers aren’t bad! “I think what’s going on here: it’s not the CUs that are the limiting factor, it’s the LPDDR5,” says AMD senior technical marketing manager Don Woligroski. “The fast memory is, a lot of these cases, what these games are really hungry for.”
all these benchmarks were run in the Ally’s “Turbo Mode,” which lets the processor draw up to 30 watts, depending on the game. The Steam Deck’s processor runs at just half that and can typically make it to the two-hour mark in all but the most demanding games with its 40 watt-hour battery.
AMD says the Z1 and Z1 Extreme are temporarily exclusive to Asus but that we may see other partners in the future with these or future Z chips — the Z handheld gaming PC branding is here to stay. Currently, it’s a partnership between AMD’s gaming group (which handles Radeon GPUs) and client (which handles Ryzen processors).
In a press release, AMD writes that Asus will announce ROG Ally pricing and “more information” about availability on May 11th
https://www.theverge.com/2023/4/25/23696722/amd-ryzen-z1-z1-extreme-rog-ally
Max 30w is for apu including both cpu & gpuThe CPU will already be holding back a higher end GPU I bet. It is only a 30w CPU at most I believe.
The price is too high! I think you can find a similar handheld at a lower price!Not really feeling it - I also agree that this thing will likely be priced above $1k due to its specs. The external GPU support is cool, but I wonder how long that sort of setup would last before the CPU starts holding the GPU back.
The rumour is that top end model costs $700 (maybe $550 for budget model?)The price is too high! I think you can find a similar handheld at a lower price!
Frankly sounds too good to be true - especially since ASUS really doesn't have any kind of "walled garden" (like Steam does with their shop) to monetize? I'd be all over it at $700 though!The rumour is that top end model costs $700 (maybe $550 for budget model?)
right. I have a 512 SD and love it, no complaints at the price point. But, if the Asus comes in at those price points. Definitely may bite.Frankly sounds too good to be true - especially since ASUS really doesn't have any kind of "walled garden" (like Steam does with their shop) to monetize? I'd be all over it at $700 though!
After looking a little more at the Ally one major thing I dont like is one usb-c port and thats it besides the external video card port. This is terrible, it could have at least used a USB-A port. I would much rather see 2 usb-c ports with a usb-a so I can have it hooked up to power, my tv, and a xbox wireless controller.
Agreed. The Ally does not seem like a true mobile gaming unit as we see SteamDeck outpace it at lower power modes. The Ally seems more like an at home gaming device to be plugged in while your are relaxing wherever and want higher end gaming. Nothing wrong with that, just figure your use case.The battery life is pretty rough, nothing a 10ft power cable couldn't resolve to still make it very mobile. Not sure why it is up against the steam deck other than the fact it is the only competitor even if it is apples and oranges in terms of performance.
| Battery Life | Steam Deck | Asus ROG Ally | AyaNeo Air Plus |
| Unlocked FPS | 81 Minutes | 82 Minutes | 79 Minutes |
| 30FPS Cap | 136 Minutes | 101 Minutes | 79 Minutes |
Older games could certainly benefit. I will admit it does seem relatively niche.A fool and his money are soon parted. Anyone who buys this deserves to lose their money.
The GPU is barely enough to push the 720P screen in anything semi recent. What makes you think it will be able to push something at a MUCH higher resolution?
