rj45, rj11 wiring
henry4994
I have to wire a new store. They are planning to use wall jacks with both phone and data line plugs in the same box. I understand 568 wiring for data using all eight wires.
I have been told that using (1) cat 5 (using cat 5e) cable coming in that I can connect to both the rj11 and rj45 female jacks.
Does anyone have the wiring codes that would work in this situation. Data lines will handle network and DSL line.
Thanks
You can split the pairs out but it's not recommended. It can cause issues with the data connection.
Run two separate cables.
Running 2 cables is almost as easy as 1, just as long as you have two spools. Do it right the first time so you don't have a headache later down the road. I'm sure *any* client will greatly appreciate it.
Bingo! My company networks most of the commercial & industrial buildings being built or renovated in the area. As a rule of thumb we run 3 cables to each drop. Then we terminate either 1-4 RJ11's and 2 RJ45's, or just 3 RJ45's, depending on whether the company has requested a VOIP phone system or a reqular copper based system.
That will allow you to plug in a phone & computer at each location, and still give you a free jack for another device such as a Network printer, or a second machine. If the company requests more then we run more. If they request less, we urge them not to and explain to them the benefits of running more now rather than trying to later.
run 2, sharing is ♥♥♥♥♥r rigging
2 cables are recommended, one thing I have found out though is that if you run a third, you are going to be happier in the long run. I finished up rewiring a business, they had 2 cat5e lines ran, then there were little linksys switches under every other desk, connecting scanners and network printers. So running a third line now gives them gigabit network. and Mid year next year they are going to IP telephones, so the network is ready.
We run 2 cables throughout the entire organization. But we use a voip system, so each single line has data + voice abilities and powers the cisco phones on top of that.
So it kinda does share, but we arent using a regular phone system.
Run the cable right once versus coming back in 6 months - 1 year and re running it. Run the two separate cables.
