rivatuner
xFuryofFivex
when im overclocking my card, i dont overclock the standard 2D? just the performance 3D?
yes, yes
happy ocing :)
remember: be smart, be safe, overclock sensibly.
You might have to overclock the 2d by 1 Mhz or something just so your idle temps don't go through the roof with some new cards (see some of the Nvidia threads).
Only if you have 6800GT / U and using some Forceware releases (e.g. 61.84). And I heard that 2D core has to be oc to at least 400, but not sure cos I have nu :D
mentok1982 said:
I always overclock both 2D and 3d to match each other.
other than temp issues mentioned above, you know that ocing your 2D has no benefit whatsoever rite?
thats whati thought.. and heard
i have oc'ed it before... i just updated my drivers and forgot which one to do
