Rift Build Take 2
[L]imey
Thoughts on this proposed build to max out Rift @ 1080p?
Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor BX80623I32100
GIGABYTE GA-H61M-D2P-B3 LGA 1155 Intel H61 Intel Motherboard
Kingston HyperX Blu 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3B1K2/4GX
Rosewill Stallion Series RD500-2DB 500W ATX12V Power Supply
Rosewill Blackbone Black Steel / Plastic ATX Mid Tower Computer Case
Seagate Barracuda 7200.12 ST3320418AS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
SPARKLE SX560T1024D5MH GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
With current promo codes and instant rebates, it puts me at ~595 before MIR, which is the top end of where I want to be.
Any thoughts?
Not good at all. Just not good at all both in terms of price to performance ratio and quality even for a $600 budget.
Please answer the stickied "ANSWER THESE QUESTIONS FIRST" so that we can help you come up with a better build.
1) What will you be doing with this PC? Rift, other light gaming, but mostly Rift. Ultra settings at 1080p
2) What's your budget? 600
3) Where do you live? AZ
4) What exact parts do you need for that budget? Cpu, mobo, ram, system drive (have external storage), case, psu, video card
5) If reusing any parts, what parts will you be reusing? Mouse, key board, monitor, dvddrive
6) Will you be overclocking? Only if necessary
7) What size monitor do you have and/or plan to have? 24 inch asus 1080p
8) When do you plan on building/buying the PC? Asap
9) What features do you need in a motherboard? Nothing fancy, this is for gaming
10) Do you already have a legit and reusable/transferable OS key/license? Yes, win7 64 bit
$208 - AMD Phenom II X4 955 Black Edition CPU + Biostar TA880GB+ AMD 880G mATX motherboard
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
$210 - XFX HD-687A-ZNFC Radeon HD 6870 1GB PCI-E Video Card
$42 - Western Digital WD5000AAKS 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$60 - Antec EA500D 500W PSU
$45 - Rosewill Blackbone Case
Total: $606 shipped
Now you have:
- A quad core CPU which will provide more of a benefit due to Rift's capabilitiy of taking advantage of quad-cores
- Faster hard drive
- Significantly higher quality PSU
- Equal GPU performance with a lifetime warranty
- More room for RAM upgrades.
Thanks danny, though I wanted to stay away from ati because of their driver issues with rift. In addition, I read over on toms that the i3 sandy bridge out performs the phenoms because of architecture improvements.... Any thoughts on an older phenom vs a hyper threaded i3?
Thanks for the chart risq, the problem is that the video card in the selected budget range is incapable of meeting my requirements.... I question why I wouldn't sacrifice in other areas to improve the gpu budget.
personal preference, if you can muster some more cash going for a 6870 will definetly pay off. or maybe look for a used 5870? they can be had for $200 maybe even $150
