Hey,
So I'm quite sure this is the right place to put this, it was either this or "cooling" as far as I could tell, so sorry if this is the wrong place
Anyways, I took these pictures of my case:
http://s168.photobucket.com/albums/u177/SynForumPhotos/Dust/
This happened in my appt after approx 6-8 weeks after its last cleaning. As you can see it's an Antec 1200, the front filters are clogged to hell, there's dust all over the NB heat sink, the GTX is caked in dust, both with the fan and simply the back of it, and worst of all, my zalman cooler is CAKED with THICK amounts of dust.
Apparently I've been going too long between cleaning it. Now I can't really lower the amount of dust in the room, or anything like that, so I have to work with this amount of dust. Obviously in the future I'll go less time inbetween cleans, but in the meanwhile (and I suppose also for future cleaning) - how the hell do I clean this?
It's too delicate (the fins of the cooler) to use a regular vacuum on (although that's probably what I'll end up doing..), compressed air will just throw it everywhere else inside the case, not helping the matter any, yet everything needs to be cleaned, like the dust that's building up on the exhaust fans and especially the CPU cooler.
Any methods for removing this much dust would be greatly appreciated.
Thanks in advance.
Thanks in advance.
