- Apr 22, 2002
Who can recommend me some decent RGB fans that don't cost $20 each?
What RGB fans are there that only cost $20? I can't think of any that cheap. $25 is about as low as they go.Who can recommend me some decent RGB fans that don't cost $20 each?
I stand corrected.
What is your intended purpose for the fans?Who can recommend me some decent RGB fans that don't cost $20 each?
What size 120mm or 140mm?Full case intake/exhaust. Including intake for aio.
Never have had experience with that brand. Those fans are rated at 54 CFM so they are kind of on the low side for air flow. There is no static pressure rating for the fan either so I am not sure how well they would work on a rad. However if this is what your budget allows for I would give them a shot and post up a review here on the forums...
All I can find are the $16 ones. I'm tempted to just go without RGB fans. The price vs performance isn't worth it to me.Doesn't arctic have an inexpensive rgb fan now?
It's really not that bad. Mostly, you set it and forget it.That's where I landed, too. I wanted RGB but was surprised how expensive they were, and Noctua doesn't make any so I'd be taking a double hit. It's hard to justify more money for an objectively inferior product. Not to mention the whole "how does all this stuff get controlled" side of the equation is still pretty messy.
