Review my upgrade
DaBear
Mainly Gaming and web/email. Games; Diablo 3, Skyrim (modded), Borderlands 2, Arma II Dayz.
$1500 w/taxes and shipping
US, Plant City, FL
CPU,GPU,Mobo, RAM, SSD, HDD, DVD-RW
Case: Cooler Master Cosmos S
PSU: CORSAIR CMPSU-1000HX 1000W
Sound: Auzentech XiFi Forte
KB/M
Re-using radiators, pump, reservoir, CPU Waterblock
6) Will you be overclocking?
Yes both CPU and GPU
7) 7) What is the max resolution of your monitor? What size is it?
1920x1200 24"
Within next 3 weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
PCI-e 3 x16, SATA 6Gb/s, USB 3, ATX form factor
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No, will buy Win 7 Home Premium OEM.
These are the parts I was thinking about:
CPU: Intel Core I5 3570K
Mobo: Asus P8Z77-V
SSD: Crusial M4 CT128M4SSD2 128GB
HDD: Seagate Barracuda 1.5TB SATA 6Gb/s
GPU: EVGA Geforce GTX 670 FTW
RAM: G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
New full cover GPU waterblock (probably EK) and LGA 1155 Apogee GTZ adapter kit.
Thanks for taking the time to review and reply!
What's the likelihood of you buying able to buy before August 31st?
HDD wise, I'd go with the Samsung F3 1TB since it's probably gonna be faster. RAM wise, do note that if you plan on using more than 16GB of RAM, you will need to upgrade to Windows 7 Pro as Windows 7 Home Premium is artificially limited to 16GB of RAM.
I can probably purchase before the 31st.
Thanks for the information on Windows 7, didn not know that.
