Reusing as much as possible build
n3zyd
I Drink & Make TITAN X SLI Decisions
*** Gaming, AA3,bfbc2,SC2,BF3
*** would like to stay under 750
*** Shamokin, PA
***CPU,RAM Motherboard sata 6.0 hd
*** Xcilo full tower case, XIGMATEK HDT-S1283 120mm Rifle CPU Cooler I5 775 AMD compatible, PC Power & Cooling Silencer PPCS750QBL 750W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply, evga 560ti fpb blueray drive, dvd burner
6) Will you be overclocking?
***yes
7) 7) What is the max resolution of your monitor? What size is it?
***27.5" 1920x1200
***next 2 or three weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
***SLI
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
*** yes, win 7 64 ultimate
I have what is in my sig, I would like to start with a I5 2500K, I found a 1155 kit for the cpu cooler above. I will be overclocking, will the cpu cooler I have be enough for a GOOD oc?
Second, as I already have a 560ti will my power supply power an overclocked 2500k and sli 560ti's that also will have a mild oc?
with the above mentioned games that I play, will a SSD drive give a HUGE boost?
You said "CPU Cooler I5 775 AMD compatible" in the your post above. Are you sure that your heatsink can support an i5 CPU? If so, you don't need to buy a LGA 1155 kit as the included LGA 1156 bracket is same exact bracket as the LGA 1155 bracket. If you don't have either LGA 1156 or LGA 1155 bracket, then go ahead and get a new one. Oh and yes that Xigmatek will be fine for a good OC.
Your current PSU will be fine, even for GTX 560 Ti SLI and overclocking
SSDs will usually only give vastly improved load times but very very rarely FPS increases.
$220 - Intel Core i5-2500K CPU
$180 - MSI Z68A-GD55 Intel Z68 Motherboard + Corsair Vengeance CMZ8GX3M2A1600C9B 2 x 4GB DDR3 1600 RAM Combo
$77 - Hitachi Desktar 7K1000.D HDS721010DLE630 1TB SATA 6.0Gb/s Hard Drive
Total: $477 shipped.
