Spartan468
- Jun 13, 2013
Alright, let me make this clear. I am one of the "old" guys.
I played my first PC Video Games in a system running Win98 more than a decade ago.
(I played my first ever Video Games on a Commodore 64.)
Now i am using only Win7, but i have many components from older systems that i want use to build a Win98 system for the sake of RetroGaming and a little bit of nostalgy.
Only gaming.
I plan to play only old PC games like Fallout 1/2/Tactics, AOE 1/2, Command & Conquer games and other games that are not compatible with Win7 or have no Widescreen Support/Patches/Hacks or look bad in Widescreen.
I hope to build it with components i have, but you can say 100$ without tax.
Greece.
None actually, unless i found later that i need something.
I hope to reuse all parts. I will have to dig them out to provide more info.
Chassis (The case of my first PC that i would like to "rescue")
CPU (Intel 3.06GHz with HyperThreading, other inferior CPUs also available)
Motherboard (i have half a dozen of them, don't remember brands an names)
Memory (Lots of sticks, i will use 4GB of the best ones)
Cooler (also half a dozen of them available, all of them are standard cooles)
GPU (Sapphire RADEON X1300 512MB, also an 128MB older card )
PSU (A cheap Chinese, about 300W, and a Greek one, made in China, 650W )
Optical Drive (An assortment of CD RW and CD RW/DVD RW optical drives)
Sound Card (Old card. Also available)
Floppy Drive (Two in working condition, one in the box, factory sealed)
Cables (An asorted pile of all sorts of cables)
6) Will you be overclocking?
No.
I have a trusty 5 year old, LG monitor with 1280x1024. The monitor is currently stored in a closet somewhere and i have to dig it out as well. I used for about 3 years.
When i find time to dig out the components.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Win98 compatibility.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I have Win98 somewhere, i guess 32bit version.
Alright, i answered the questions.
My main concern is about the drivers. I do have the CDs, but these are the drivers from the box. I want the last drivers.
My Sapphire RADEON X1300 can play even CoD:MW. It would be great if i can use it and make a PC that can play all the good old games.
That is all for now.
Only gaming.
Greece.
No.
