- Dec 19, 2005
"The chip had 125 million transistors on a 0.13 micron process. With 128 megabytes of 733 MHz GDDR3 memory, the board needed an extra power connector that could draw 20 watts. The price was around $300. Quite a bit for a card that did absolutely nothing without specialized software.
There was a physics engine, NovodeX, that could handle game physics for developers using either the chip or a software stack, so we presume that’s what most gamemakers would use.
Of course, today, a 20 watt GPU with an extra power connector isn’t enough to make you look up from your screen. But times were different then. According to contemporary reports, the chip has a two terabit per second memory bandwidth. Watch the demo vide below. It won’t knock your socks off, but for a computer system nearly twenty years ago, it was pretty good."
https://hackaday.com/2024/05/06/ret...mputers meant for big,a constant in one swoop.
