erek
- Dec 19, 2005
Staying with Windows 98 SE. looked up some reviews and that solidified my decision:
https://www.anandtech.com/show/580/5
That card is good for that generation. You won't be disappointed.Staying with Windows 98 SE. looked up some reviews and that solidified my decision:
it was a lot of Riga moral to get the drivers installed!That card is good for that generation. You won't be disappointed.
doesn't feel pure enough to go SSDs in my humble opinion :-\If too OT feel free to move.
I note you are still using older spinning disks... did you consider using SSD's? I know no support for TRIM an such. I've got a few Win98 & Win 2k rigs (and lappys for that matter) that I've been considering "upgrading" with SSD's as those spinners will go eventually.
I Hear ya. Some years back I bought a handful of SATA to ATA drive adapters as I was getting concerned about the age of the spinning disks in some of my older rigs.doesn't feel pure enough to go SSDs in my humble opinion :-\
i already question how it seems i'm going with the almost, most high-end hardware for some of the builds
like it's unrealistic in 1997-98 for the Voodoo1 build to have 256MB of ram... 64MB was more practical...
also for the Voodoo5 build the Audigy 2 ZS was the best, i remember wanting those types of cards but could never afford them, so it's a little unrealistic and unauthentic of an experience even as it is?
i've got a WD400 for the Voodoo5 build, opinion? Evil ScooterI Hear ya. Some years back I bought a handful of SATA to ATA drive adapters as I was getting concerned about the age of the spinning disks in some of my older rigs.
I used to run a lot of 18k SCSI drives back in the day. So many Adaptec HBAs.I still have the WD 80JB I used with my XP system, still worked fine last time I fired it up. I also second staying away from the IBM drives, they were really fast...but they all will die eventually. I had a lot of friends end up with dead drives, heck I even had my 18 GB SCSI Ultrastar die from the click only after about 20 hours of use. At least for my RMA I got a brand new 36 GB drive to replace it which was a massive upgrade.
The DeathStar is so much faster on Access Times and Reads^^ Probably fine with that you have... just stay away from the IBM deathstars... click of death still haunts me... lol.
I have an old Voodoo3 and an ATi Rage 3D PCI IIC for those games even older that require DOS to run and 3DFX, but my board is not a universal AGP slot. I have a Soyo KT880 which is, but it needs to be re-capped on the power phases to the CPU for it to work, as of right now it just turns on and nothing happens sadly.
I'm pretty confident that is it based on issues of that timeframe. The capacitors of a very specific size on that motherboard are all "leaking" and puffed out. Most are on the CPU power phases; but some of the same size are elsewhere on the motherboard as well.I do recapping if the capacitors are genuinely bad.
Let me know if ur interested in pictures I guess, can't hurt to explore the idea.
i wanted to explore an original Raptor, but that's not IDE, apparently it's SATAWould an SSD or Velociraptor work?
You'll be wanting an Adaptec HBA.. they are supported all the way back to DOS... lol... ASPI!!!i wanted to explore an original Raptor, but that's not IDE, apparently it's SATA
think my EPoX 8K3A is IDE only
I've got a Maxtor Atlas 15K II SCSI Ultra 320 drive, but my controller,LSI Logic LSI21320, isn't support in Win9x as far as i can tell
those Adaptecs were the most desired, but so expensive back in the dayYou'll be wanting an Adaptec HBA.. they are supported all the way back to DOS... lol... ASPI!!!
the flash storage media makes the build feel weird and non-era appropriate for me just can't do iti tend to use kingspec or transcend IDE SSDs when repairing older things. or an IDE DOM if you have a very tight space and only need a few GB.
I had bins full of them... which I just recycled a little bit ago. Same with 15k drives... I might still have a few laying about... lol.those Adaptecs were the most desired, but so expensive back in the day
i never got one... had 2 LSIs and one time an Mylex AcceleRAID 352 but unfortunately had two mismatch (generations) Seagate cheetah 15K.2 and 15K.3 drives, so the performance was horrible in RAID0 on a 32-bit 33MHz PCI bus
The MSI K7N2 is such a great board (all variants)...Here is my current Retro Gaming PC Build...
Running Windows 98SE with memory > 1GB RAM patch and allocation for a 512MB AGP Aperture size.
- MSI K7N2 Delta nForce 2 motherboard
- 2GB OCZ DDR 400Mhz 2-3-2-4 @1T in Dual Channel Mode
- Athlon XP 2800+ OCed to 2.5Ghz
- Gainward nVidia GeForce 6800GT AGP 3.0 256MB (Running nGlide in Windows 98SE and Windows XP for Glide Games)
- 160GB 7200 RPM IDE drive (Windows 98se, Windows XP and a data drive all partitioned)
- Creative Audigy 2 ZS, using SB16 emulation for DOS based games
- D Link Wireless G PCI card (managed to get it working in Windows 98SE too!)
- 56k Modem (why not for old times?)
- 3.5" Floppy Drive
- LG 16X DVD/CD Reader
EDIT: picture attached as promised...
Wanna sell it?I just found this earlier today. Wish I knew if it worked or not.
Those IBM death-stars were quick drives.i've got a WD400 for the Voodoo5 build, opinion? Evil Scooter
"Both Fujitsu and Western Digital showed that they are absolutely able to build technically competitive hard drives. I still remember the staff of a local computer shop going on about several hard drive companies just because they were not selling high capacity drives. This review shows that there's more to hard drive technology than only high capacities. After all, the average size of IDE hard drives is still less than 30 GB."
Source: https://www.tomshardware.com/reviews/ide-hard-drives-20-gb-platter,275-12.html
Of all the awesome things to just find.... lolI just found this earlier today. Wish I knew if it worked or not.
Definitely let us all know it's status when it arrives!Wanna sell it
got 2D to boot, but 3D its having some difficulty. wonder if it's just dirty or something, this while trying to launch quake3 arena. machine hard locksDefinitely let us all know it's status when it arrives!
single gpu mode it worksgot 2D to boot, but 3D its having some difficulty. wonder if it's just dirty or something, this while trying to launch quake3 arena. machine hard locks
