deadman_uk
- Jun 30, 2003
Hi, just wanted to know if it's possible to Retrieve data from hard drive after a quick format and a full format.
If so, how is this possible?
Late to the party, but once again, TestDisk can work wonders in this kind of situation.
There are two kinds of formatting these days (pretty much on any platform OS): standard format and "quick" format.
The standard old school method literally rewrites the file allocation tables and then writes a zero to every data sector on the drive that's used for file storage. It also reads the data back in immediately afterwards so it can tell if it's a bad sector or good; if bad it marks the file allocation tables (FAT, MFT, etc, each platform filesystem calls it something different but the principle holds), if good then it moves to the next and continues to the end of the writable user accessible portion of the drive. Part of the reason the standard format procedure takes so damned long is because of that process of writing/reading/verifying/move on.
Quick formatting saves a lot of time because it basically zeroes out the file allocation tables (as detailed above) and that's it. Think of quick formatting a hard drive like taking a book with a table of contents and erasing the table of contents: the actual chapters are still there, the writing/content is still there where it originally was. All you did was erase the table of contents, so if someone came along and wanted to put in new material, they would create a new table of contents and then start dumping data wherever the TOC has the stuff listed.
The original content is still in it's original place when you quick format a hard drive, hence having a relatively easy time with data recovery after doing a quick format - the data is still there, where it was originally, you just "wiped the slate clean" in terms of the table of contents.
When you full or standard format a drive, that data is more than likely going to be overwritten by zeroes and you're going to lose it most likely. So, in this day and age, and considering how large hard drives are getting, quick formatting gives you basically the same results (a drive you can use) while preserving data in a recoverable format if you happen to accidentally quick format the drive or do it and realize it was a mistake.
And just to answer the actual question, yes it is possible to recover data from a hard drive that has been quick formatted and yes it's even possible to get data back from a fully formatted drive as well depending on how much time, effort, patience, and of course money you're willing to spend. The only way these days to effectively "destroy" data on a hard drive is using software like Eraser which uses the DBAN engine to truly overwrite data sectors on a hard drive multiple times with totally random magnetic data. Even the NSA would have issues recovering data from a DBAN-wiped drive... but quantum theory holds even then it's possible.
Hope this helps...
Yes, that helps very much, thanks alot for typing all that, much appreciated!
Hope this helps...
I have testdisk also, i use GetDataback for data recovery and testdisk for recovering partition tables
The only way these days to effectively "destroy" data on a hard drive is using software like Eraser which uses the DBAN engine to truly overwrite data sectors on a hard drive multiple times with totally random magnetic data. Even the NSA would have issues recovering data from a DBAN-wiped drive... but quantum theory holds even then it's possible.![]()
