Restoring to dissimilar hardware...?
Coldblackice
Do any of you ever do this?
I'm debating between buying the Standard or Pro versions of Macrium Reflect. The big difference between the two (besides dynamic disk support, which I never use), is restoring to dissimilar hardware.
Would any of you ever use a feature like this? I'm wondering if it's a potentially mishap/bug-ridden feature that's meant for the simple home user, who doesn't know how to go through a reinstall, and would much rather just have a program automate a transferring of one system to another.
I imagine a process like this could/would be ripe with potential bugs, hiccups, and headaches, which would be avoided with just doing a fresh install on new hardware, and then restoring selected parts from the backup.
I suppose it largely depends on what hardware changed inbetween. I just don't know if I'd trust a program to take one system's image backup and translate it to another system's, unless it was purely just a matter of "transcoding" the hard disks' size/alignment/layout/etc.
Acronis has a similar feature and I think I did it once. Most of the time I don't bother and just put the old windows drive on the new motherboard, often it just works. With XP I often used the repair option but with 7 you have to be able to boot to do that, so a commercial solution might be better. I never "start fresh" that's for sure, my XP lasted almost 10 years and countless motherboards, my 7 is on its third motherboard. I wanted to upgrade from XP to 7 but from 32bit to 64bit there is no way.
I still use the old XP sometimes, I converted it in a vmware virtual machine !
On windows and on linux I have successfully used DD multiple times to restore to dissimilar hardware. Meaning an exact bit for bit copy was all that was needed.
Don't bother with it.
It's a hassle and needs all the drivers from the new equipment.
Save your cash unless you have a need for computer migration for system recovery, testing and other purposes.
