If I'm logged onto windows XP via remote desktop from somewhere else...is there a way to restart the computer? The usual "turn off computer" button in the start menu turns into a "disconnect" button in remote desktop...
hit the start button then run and type shutdown.exe -r
If you want to know the extra options you have open up a command prompt(cmd from the run prompt) and type shutdown. It will list the switches you can use.
