i can agree to 'easier' as far as bleeding/filling, but 'safer' is only true because there is 1 less connection to connect... i've used both various times in the past, and reses have always given me a bit of trouble.. that's probably because i custom-make them, though.thewhiteguy said:You can't beat a PVC res, it's safer and easier than using a T-line.
I think it's safer becausediredesire said:i can agree to 'easier' as far as bleeding/filling, but 'safer' is only true because there is 1 less connection to connect
1. Depends on the layout of your res and barb placement, and pumps are designed for various applications like aquariums and pumping chemicals (in some cases). Also: you should flush the system for a while if you're safe anywaysthewhiteguy said:I think it's safer because
1 - It is a place where anything bad like metal would collect instead of screwing up the pump.
2 - It's a nice place to put a drain for draining out the loop easily.
3 - You can fill your system without running you pump dry so much.
4 - If for some reason your loop leaks or sweats, you'd have to be a retard to let the level get low enough to burn out the pump from running it dry.
depending on the design of the res, it's probably WORSE than a t-line... in general (in my experience)... considering there are barbs on a res, too.Erasmus354 said:a resevoir can lower temps over a T-line, depending on the size of the T-line you were using previously, a 1/2" T-line is like sticking a piece of 3/8" tubing into your system, it is a source of restriction. Now the gains from taking this out will arguably be very minimal...and you could just get a slightly oversized T-Line to take the restriction down to almost nothing.
BioPort said:Shampoo Is Better!
No Condtioner Is Better!
What Are You Staring At, Swan?
texuspete00 said:I don't know about you but that half hour is the first part of my leak test anyways. I never have to bleed again. T-Lines all the way. I got enough junk in my computer. I'll admit I'm a bit jaded. I had the DD cylindrical res and it cracked, probably the water flowing through those barbs in part. I had twisted in the barbs cute hard and that that ended up stressing the area around it. After a month or two it cracked. No res for me anymore.
