Researchers Develop Heat Sensing Transistors
AlphaAtlas
Heat is the enemy of high power electronics. As chips continue to shrink, power density has been steadily increasing, and it's becoming more and more difficult to effectively protect chips from heat damage. But researchers at Stanford university have come up with a solution can be baked into silicon itself. According to the researchers, their "heat transistor" can function like a thermostat, switching on and off to protect sensitive areas of a chip. Unlike previous implementations, such a heat transistor layer would only be 10nm thick, work well near room temperature, and allow fine-grained regulation across a chip.
In a more distant future the researchers imagine that thermal transistors could be arranged in circuits to compute using heat logic, much as semiconductor transistors compute using electricity. But while excited by the potential to control heat at the nanoscale, the researchers say this technology is comparable to where the first electronic transistors were some 70 years ago, when even the inventors couldn’t fully envision what they had made possible. "For the first time, however, a practical nanoscale thermal transistor is within reach," Goodson says.
Interesting. That would work far better than a PTC in power electronics. I wonder what the advantage of this is over having a chip connected temperature sensor or sense diode.
So, this isn't a thermistor? Or, it is a thermistor, but they didn't want to call it that for whatever reason?
Don't see why they wouldn't want to though...even if it's just a really small thermistor, it's still an impressive accomplishment.
Benefit is it can passively control power based on the heat it detects, whereas you would have to actively control power with a processor if you used a sensor instead.
Summary makes this quite unclear, it's a electrically actuated *thermal* switch.
As in, a material that changes thermal conductivity when a voltage is applied across it.
This would just reduce complexity/cost for what AMD and Intel already do with turbo/PBO etc. Basically allowing more simple chips to be self regulated without a software/hardware layer dedicated to it. Wouldn't be fun if they are not so reliable though lol...
^^(or like Nv has done for GTX 10 and 20 series instead of fancy voltage regulators in place of more beefy cap/vreg design..maybe something like this can help to keep temperatures in check without adding not the greatest success rate from fancy designs as can be seen from the issues they have had with 2080ti ^.^)
I wonder if this can help mitigate the "reward" of dark silicon as they get smaller and smaller chips as a result of die shrinks, maybe these can be part of the "dark" transistors that overall sound inevitable?
