Hello all. I'd like your comments about the following config. Though I know more about computer components than I ever did before, my knowledge is still quite limited and I'm very capable of messing stuff up. Any comments, criticisms or suggestions would be very welcome.
Gaming
$1500 or so [edit: this is max; less is better]
3) Where do you live?
US
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything except monitor
Monitor, 22 inch
6) Will you be overclocking?
No
22 inch, might get a second one in the future
Within one month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Dual monitor support, but that's secondary
10) Do you already have a legit and reusable/transferable OS key/license?
No
Antec P183
Corsair TX 650W
GIGABYTE GA-MA790X-UD4
AMD Phenom II X4 920 2.8GHz AM2+
8GB (4x2GB) GSkill DDR2-1066 F2-8500CL5D-4GBPK
WD6400AAKS Caviar Blue 640GB 7200 RPM
SAPPHIRE Radeon HD4870 Vapor-X 1GB (chosen for low noise)
Samsung SH-S223F 22X Dual Layer DVD+/-RW SATA Drive (also chosen for low noise)
Scythe Mugen 2 HSF
Scythe Slipstream SY1225SL12M (x2, maybe x3)
Scythe S-Flex SFF21E (x1, for blowhole on P183)
Scythe KM02-BK 5.25" Bay Fan Controller
Gaming
US
Monitor, 22 inch
No
Within one month
No
Antec P183
Corsair TX 650W
Scythe Mugen 2 HSF
