Replacment heatsink for 9700pro
Bigntasty
The fan on my 9700 pro started spining very slow so I need to find a new heatsink for it. I can't rma it. I have also been haveing trouble with artifacts so I think I definatly need a new heatsink. Which one should I get and where can I buy one. I would also like one that is easy to install.
Thanx a lot for your help.
I have a AIW 9700 PRO that the stock cooling dosen't seem to be cutting it. Would like some recomendations also on some good O.T.S. cooling systems for the 9700.
Pittbiggdaddi
I had a vga silencer on my 9800xt and it worked great. Temps in my case went down a few (it expells hot air thru the back of your computer) degrees and my core about 10 degrees. What I miss the most is how quiet it was. I have a 6800gt now, and it's a lot louder. Just my 2 cents.
