Replacing rig
  • Thread starter Deleted member 88227
  • Start date
D
Guest
If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
Gaming mostly. First person shooters (serious sam hd, battlefield bad company 2, battlefield 3, battlefield 2, counter strike, cod, etc..)
$1000 and that price is pretty firm.
3) Where do you live?
Biloxi, MS
CPU, Motherboard, RAM, GPU, PSU, Case, Harddrive(s),
Probably wont be reusing any parts, but I do have:
Intel Q8200 @ 2.33Ghz
Nvidia 460 GTX
4GB DDR2
Two Raptor 15k RPM drives (old ones, the F3s are prolly faster now)
Corsair 620W or 520W PSU (couple years old now)
6) Will you be overclocking?
Open to it.
Currently got a 25" 1920x1080
Next week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
What I would love to have is a tripple monitor setup, but I'm not sure the budget allows that. Obviously not including the price of the monitors.
Windows 7 64 Bit
Basically this is a friends computer and he really wants to upgrade to a new system, but he doesn't have much money to spend. I told him unless he plans to set aside ~$1500 and go with an 2500k build with a 6950 (or higher) video card I don't think it would really be worth it. So he has ~$1000 to spend, is it worth him getting a completely new rig? If not, what parts can he upgrade?
Your friend does not need $1500 for a new PC for gaming only on a single 1080P monitor:
$333 - Intel Core i5 2500K CPU + MSI P67A-G45 Intel P67 ATX Motherboard Combo
$65 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$280 - XFX HD-695X-CNDC Radeon HD 6950 2GB PCI-E Video Card
$65 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$90 - Corsair 650TX V2 650W PSU
Total: $833 plus tax and shipping.
Have your friend choose his own case. I recommend the following cases:
$70 - Lian Li Lancool PC-K58W ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$110 - Lian Li PC-60FN ATX Case
$110 - Lian Li PC-7FN ATX Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$127 - Fractal Design Define R3 Black ATX Case
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Lian Li PC-9F ATX Case
$143 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$150 - Corsair Graphite Series 600T ATX Case
$155 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$160 - Silverstone RV02B-W ATX case
$178 - Silverstone RV02B-EW ATX case
$190 - Corsair Obsidian Series 650D ATX Case
That setup will be significantly faster than his current setup?
Thanks Danny, you rock.
PS
His setup is probably gonna be faster than mine now. Gonna have to fix that. *sigh*
PS
Not probably, It will the Sandy bridges are killer gaming CPU's and a 6950... Nice.
Is the Redline.org for all of the gulf coast? I live in Houston.
Just assuming he takes my advice (Well Danny's) and gets the SB setup, he is usually pretty stubborn.
I live on the MS coast, so the site is mostly people from this area... You're more than welcome to sign up though as ideally I'd like it to be for people from the entire Gulf coast area.
What about triple monitor setup in the future? Will he be able to just add a second 6950 and two more 1080P monitors?
Heck AMD cards let you go triple monitor with one card. Two would be better, but one will work
Yes using a display port adapter, but im more worried about gaming at that resolution. Pretty sure the psu will handle it, maybe an antec trupower 750
He would need a larger PSU for HD 6950 2GB Crossfire. I would not recommend the Truepower New 750 on account of its high costs at the moment. I'd go with this PSU:
$110 - Corsair 750TX V2 750W PSU
Thanks again Danny.
He's gonna go ahead and get the 750TX, display port adapter, two more monitors and see how it goes. If it doesn't work out, he'll grab another 6950.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204 - dvd burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216 -case
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185 -HD
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009255 -two monitors
http://www.newegg.com/Product/Product.aspx?Item=N82E16814999034 -third monitor cable
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150550 -video card
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139022 -psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314 -ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130582 -mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072 -cpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065 -cpu fan
This is what is sitting in his shopping cart, yes/no? Plans to use three monitors with this setup (those two 23" and a 25" @ 1920x1080)
He also has a 4 pack of 120 mm fans and an 80x15mm fan (for the CPU back plate). Not sure that he needs any of this.
Also pretty sure that 850W PSU is a bit overkill (he will probably be getting a second video card later)
Get the CPU and mobo from the combo link I first provided in this thread. That's gonna shave off $20 right there. HSF wise, ditch that overpriced Coolermaster and go with this HSF:
$30 - Xigmatek Gaia SD1283 120mm HSF
DVD burner wise, ditch that Asus and go with this cheaper Sony DVD burner:
$19 - Sony AD-7260S-0B SATA DVD Burner
Thanks danny, real bummer that the CM 212+ is so expensive now.
