Hi everybody. I've been at this for a while and I need some help. In advance of building a new PC, I'm about to install a new hard drive into my old single-core computer from way back in 2004. But before I do that I want to and may need to fix a problem that's been going on for a while, and that's the focus of this topic.
Two years ago I installed a GeForce 6600 GT into this computer (Athlon XP 2800+, Asus A7V8X-X mobo, Apex/Allied AL-A350ATX 350W PSU). Everything worked fine, but I promptly got the following message on startup:
"The NVIDIA System Sentinel is reporting that the NVIDIA-powered graphics card is not receiving sufficient power.
To protect your hardware from potential damage or causing a potential system lockup, the graphics processor has lowered its performance to a level that allowed continued safe operations."
At first I was going to fix it, then later when nothing bad happened I just got used to it. It's still going on today, every time I reboot the computer.
Now I'm wondering if it's been incredibly stupid of me to leave it for so long, and I have no idea so I'm asking you guys instead. Do you think, over the two year period, it's resulted in some kind of damage? Hardware damage, file corruption, things like that? Just a guess would help.
I looked at the stickied PSU list in this forum for replacements but I'm really not sure what'll be compatible with my now old computer. Can someone please direct me to a good, more powerful PSU that will work with the computer and that won't give me these problems? Check out the stats on the Newegg page for the current PSU details. Newegg says it has SATA connectors, but all I see are 4-pin molex ones; I have to use a SATA host controller for the HD. Newegg also describes it as AL-A350 but the picture says AL-B350.
Oh, and like I said I'm trying to upgrade the hard drive, so the new PSU should be able to support a WDC Black 1TB 7200 RPM 32MB 3.0Gb/s as well, if this computer even can support that HD.
One other thing. If I do upgrade to a non-error message-causing PSU, will it make the video card more powerful? The 6600 GT's message did say it had deliberately lowered its own performance level.
Any help would be much appreciated.
