nytrackstar
- Aug 3, 2004
i made this post in the motherboard forum as well, not sure where it belongs...
Is it possible to replace the heatpipe of the a8n32-sli motherboard? i'm putting together my watercooling kit, and as you can see in my sig its in an upside case.
I've seen people replace the heatpipe on the a8n-sli premium with heatsink as well as little heatsinks right next to the cpu (not sure what that is cooling, it is where the fins were from the heatpipe)
assuming i remove the heatpipe, what do i need to cool? northbridge? southbridge? those little power things next to the cpu? i dont think i want to add any of that to my water loop cause its got enough heat sources as is...
any sugguestions would be helpful, also what type of passive cooling products would do the job..
thanks alot
thanks alot
