Replacing 680i with New 680i Quad Core Fix
Digitalcaveman
Guys,
Had a question as I'm getting my existing 680i board replaced with the EVGA's fix for Quad Core Processors. Basically it addresses the inability of the old board to OC the FSB. This has been fixed and they are shipping out new boards.
My question is, if I just swap out the board with the new one, all my programs and WindowsXP should still work fine right off the bat or are there some things I need to do to make it work correctly?
Next Question: Will replacing the board have any impact on my Raid 0 config?
Thanks much for your input,
DC:cool:
Shouldn't affect anything on your RAID (that is, it won't make the RAID0 suck any more than it already does :p). Windows should be fine as well. Go for it.
is evga swapping out 680i's for new ones with some kind of modification? or is this a firmware fix? they havent emailed me about this (i have many many items registered with them) but they dont seem to have a problem emailing me with all kinds of other bullshit.
n/m found it. real nice.
They are replacing boards for people running quad-cores. It's a physical change, not a new BIOS/firmware. And OP, it'll be plug-and-play. As long as you keep all of your BIOS settings the same between boards, Windows won't even know anything happened.
What kind of hardware changes did they make? New chipset revision?
yes and they are cross-shipping the boards (free shipping both ways), so you wont have any downtime except when you swap out the boards. mine is on the way. i dont have qc yet, but i will next set of cpus that are released.
My system went back to VM last week for other reasons but in the mean time it was found the voltage regulator was 'hissing'. apprently on several boards made in the same batch. I found out from abother [H] user that the FSB was limited to 1300 rather than 1330.
If you want the new board you have to request it don't you? It's not a widespread "recall" or anything like that right?
Correct... You have to ask for the replacement, it's not a total recall of all boards. If you have a Duo you won't notice any difference, the fix is only for Quad core users really or if you plan to upgrade to a quad core down the road. I have been watching the message boards at EVGA recently..
Smitty
As of March 5, Newegg and other retailers are now selling the A1 and T1 evga Mobos, FYI to buyers.
also i read that the components on the reverse side of the board the made modification of hs/f brackets necessary has been fixed. i love evga. it took about 2 or 3 hours from when i applied for rma to shipping confirmation.
its the same (ref) board as the evga, as is the biostar and the xfx, but so far bfg has not copped to any qc probs, and is definitely not cross shipping new rev boards to anyone.
That's cool, all good content. Yes, mine should be here tomorrow and I'll be trying out the overclocking of the FSB once I get it installed. Hopefully this will work well as my Quad Core is hungry!
