Replacement motherboard...any suggestions?
FreakyT
My current motherboard (came in a VINTAGE AE-1 barebone system) has been acting strangely, and also seems to have compatibility problems with most operating systems, including, to a degree, Windows, so I've decided to buy a new one. I'm not planning on spending on any more than $70, I already have a Sempron 64 2800+, and I'm using an AGP card so I've decided an nForce3 chipset would be the way to go. I'm looking at the following two, primarily:
MSI K8N Neo-V
BIOSTAR K8NHA
From what I've read, the hardware in the former seems to work well with Windows XP, Windows Vista, Mac OS x86, and Linux, whereas I can't find as much info on the latter's compatibility, particularly about its ethernet. However, the Biostar one comes with Firewire ports, which could be worthwhile for the extra $10.
Has anyone had good or bad experiences with either of these? Or could recommend a better one?
I'd probably stick to MSI too, but if you need firewire why spend extra money for an add-on card?
