Replacement for Antec NeoPower 480W?
sanchez_1960
Basically I had an issue with my Antec NeoPower 480W where when you first plugged it in in the morning, it'd take ages before the power button would respond. Over time it would get longer and longer.
I lived with it by leaving the power switch on for the PC. Last week I decorated my room so had to unplug and remove it all. Put it all back and now the power wont respond at all, despite being plugged in for 24 hours now.
Is this a common problem with this PSU? The mobo light is on but no response when I press the button.
Anyway, I'm looking to replace it ASAP cuz I need my computer back!
1. I've been happy with the noise of the NeoPower so something of a similar db would be great.
2. Something that has the modular connectors for it would be even better.
Any recommendations?
Just do a search for Hx520 or Hx620. You will find all you need to know.
Cheers guys, ordered the Corsair!
I unplug it out of habbit, stupid really but after i started getting that issue I stopped doing it! I just hope it is the PSU to why my system wont turn on!
