TeleFragger
- Nov 10, 2005
Ok so I was given a computer from someone.. no hard drive but it was complete..
I plugged it in and it powered up... however said chipset heatsink not found powering down...
so I opened itup and you can see the heatsink is missing..
what it appears is that there is a Z that holds the heatsink down... well someone ripped it off... so 1. I am going to try and solder a wire on to each location as they ripped the hoop out that holds down the heatsink (and yes I will put a heatsink on it)
I cant really find a replacement mobo even on ebay.....well one that is worth buying.. one guy has his up there and it too is missing the chipset clamp...
anyway.. this is a small computer and I was going to put it in my entertainment center..
p4 2.8ht - 512mb ram (was going to upgrade to 2gb pc3200) and put vista on it... as my media center pc.....
so should I just throw this puppy away? buy a motherboard?
or is there a small form factor computer out in the market that is relatively cheap for what I wish to use it for?
I have a xbox 360 and set it up last night as a media center extender.. but it wont play divx avi movies... well it will if you put a pen drive in it with the movies... but I want to use my vista box to host them.... I have 16hrs of family videos I have created.... I just dont want to convert them to wmv........
what would you do?
Thanks
~Jeff
what would you do?
Thanks
~Jeff
