Repairing a C2D mobo
Modred189
Can't Read the OP
Repairing a pin...
So I have this Asus P5NSLI, and it has a pin that seems to be broken.
I got the board for super cheap, so I was wondering how possible is it to repair a broken pin on a C2D mobo?
Does having another nearby help? (as a supply of extra pins??)
Assuming you meant pin in the socket, if you got some killer soldering skills, give it a shot. Otherwise, GG P5N SLI. See you in MB heaven.
What I've had to do for a board that had damaged pins in the socket.
Turn the CPU over and actually... increase the size of the corresponding pad with solder.
That's right... figure out which pin it was, solder a blob to it so it contacted the pin.
Good luck, especially because the pins are diagonal past about a 1mm... Very easy to short something.
