Hey to everyone in this awesome forum. My current computer is getting old, its been 2 years and it has serve me good so now its time to build a new more expensive machine. I will have arround 3k to buy a computer without screen. Exciting because it will be the most expensive computer i ever bought and therefore the best (by far ). I need this computer to be my work computer, very little play on it, i am going to be using alot of after effects, cinema 4d, maya, pshop, illustrator, some premier/avid, some shake and would like to isntall osx to use finalcut pro (my fav of the 3 for video editing).
So i have been researching and researching cuz although 3k seems alot its not as much as i though. Parts i already have are, keyboard (my faithful 10 dollars logitech), mouse (510mx), screen (samsung 21" 215tw), ocz 600 w power supply, decent pair of speakers.
And these are the parts that im planning to buy:
-Intel QX6700 - $1099
-EVGA nForce 680i SLI NVIDIA Socket 775 ATX Motherboard - $249
- 2x CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 - $305x2- $610
- Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM Serial ATA150 - $229
- 2x SAMSUNG SpinPoint T Series HD501LJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s - $150x2 - $300
- COOLER MASTER CM Stacker STC-T01-UW Black/ Silver Aluminum Bezel - $145
- COOLER MASTER eXtreme Power RP-550-PCAR ATX from factor 12V V2.01 550W Power Supply - $70
- NEC Black 18X DVD+R 8X DVD+RW 8X DVD - $30
- Noctua NH-U12F High Performance Cooler - $65
- Steelpad QCK+ Cloth Mouse Pad - $15. im retiering my ratzpad
- Gfx Card ?????
Price $2646 (shipping should be a good $100) so $2746
Ok, so these are the components i chose. The powersupply will go with my 600W ocz on the cooler master which has dual psu so ill b pushing 1050 which is more than enough. My question is abut the other components, are they all quality components? would you change some and why? Main complain i see is the evga mobo (but the asus costs 50 dollars more with so much less features, seems like a rip off), the samsung hard drives (been having samsungs and they been nothing but good to me, plus they are gonna be my non working hard drives, they just store info, and i back up stuff that i really need). Also im not sure what gfx card to get, i wanted one of those dx10 cards but im not going to be playing any games (i have a console for that), and it really doesnt matter what graphic card you have when you are rendering, I cant (and sincerelly think they are a rip off) afford a quadro and i think that a mid range gfx will do me good (going from a 6600 gt), so what do you think for max 300 dollars? I was thinking of the 7950gt, or should i go for the 7900gt? I was recommended the 7900gto but i cant find it anywhere and it seems to be about 300.
please feel free to add components, change components. I really appreciate it. thank you so much,
Paulo
- Gfx Card ?????
Paulo
