Removing MSI HSF
hey guys i recently purchased the MSI GeForce 6800.
its got the big copper cooler with the sideways rotating fan...link...
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=321902
i want to install this on it....( to quiet my system down )
http://www.svc.com/zm80d-hp-75.html
i allready have the zalman HSF because i had it on my r9600 PRO.
but i dont know hwo the stock HSF on the MSI is attached i unscrewed all the screws but the HSF was liek " thermal glued " or sumthing.....and help is appriciated.
i'm gonna have to say not to install that heatsink. i have the little brother of it on mine and i just don't like it personally.
plus i just don't think it'd fit. wait until the nvidia version of the artic cooler is out.
i was gonna wait for the VGA silencers to come out for it but i figured that this zalman would be good for the mean time since i ahve it alying around doing nothing, although it barely fits in my case under my coolermaster hyper 6 CPU HSF thats mroe liek a sky scraper.
oh well for when the VGA silencer revisions come out for the 6800's, anyone know how to get the stock HSF off the MSI boards.?
It can be done.
http://snipershide.free-universe.com/remotes/zalman_zm80d-hp/
Just requires a bit of time and effort to figure out a good configuration that uses just the available stock items.
Note that in the http://snipershide.free-universe.com/remotes/zalman_zm80d-hp/zalman_layout/ is a two arm per side configuration, and in this folder, http://snipershide.free-universe.com/remotes/zalman_zm80d-hp/zalman_layout_2/ is a four arm configuration which is what im currrently using.
I won't tell you to go ahead and do it, as it is definately not ideal, just that it can be done with good results.
http://snipershide.free-universe.com/remotes/zalman_zm80d-hp/temps_again.jpg
Idle Temps 77.5 F Ambient Room 4:35 PM
Nvidia sensors
Ambient: 35 C
GPU: 53 C
MBM
CPU: 111 F
Case: 89 F
Load Temps 77.5 F Ambient Room 4:48 PM
Nvidia sensors
Ambient: 46 C
GPU: 67 C
MBM
CPU: 122 F
Case: 96 F
My initial load GPU temp before putting the Zalman on was 84-85 C
