removing 200MB EFI parition
antok86
i cant remove this 200mb EFI partition thats on my hard drive. all the options are grayed out. trying to format the drive clean
use diskpart from a cmd prompt.
list disk<enter>
select disk ?<enter> ?=disk number the 200mb part is on
clean<enter>
**all partitions on the drive will be gone**
