Is there anyway to get Remote Desktop to work with Win 2000 Server? I see the client you can download and install, but it's only the viewer...doesn't allow incoming connections. Is there anyway to do it using the normal terminal services, or using the web version? I plan to monitor the server using my XP Pro desktop, and I've always used Server 2003 in the past. I'd like to use 2000 for a change (since it's an old server) but I don't want to pay for any 3rd party software. I'd rather not use VNC either, because if it gets to the point of using 3rd party software, I'll just load Server 2003.
