Bluedragon9r
- Nov 11, 2004
To the best of my knowledge, you want to have a reservoir at the highest point in the system. That would provide maximum NPSH to the pump, and also ensure that any air in the water will eventually work it's way to the reservoir. I know this is true for much larger cooling systems (which I know from my work). The question is, how much does it matter in a PC cooling system?
The reason I ask is that I'm working on back fitting some higher end watercooling components into a case that had a built-in system. The 2x120 rad will go in the top of a Lian Li V1200 case, and the reservoir will be a couple inches below it in the 5 1/4 drive bay cage, then the pump will be mounted to the bottom of the 5 1/4 cage.
Do I really need to worry about air getting trapped in the radiator with this setup? Or should it be OK once it's bled?
