Hey people. I am trying to get several very important files off of a clients home computer for them. One of the registry hives was somehow corrupted, giving the error:
After investigating, and applying the information found HERE, the hard drive still will not boot up and causes the system to perpetually reboot when the BIOS goes to load Windows on the HD.
Question? Even with a borked registry, if i change the jumpers on the drive to slave (it is an IDE Maxtor) and plug it into one of my main systems, should I be able to access all the data files on that disk??
Please advise on any possible options you all might have! Thanks.
Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SO FTWARE or its log or alternate
