Refurbed X850XT AGP $125.77
so i jumped on this the second i saw it...but how do i fit this dual slot monster into my shuttle sn95?
Use a tool to cut the extra metal bar, that's what I did to fit a X850XT in my Shuttle.
annaconda said:
Why would you buy a refurbished hard drive for $70. when you can get new one for $89 300GB
Where can we get a 300GB for 89.00, and is it Sata?
Z
He was probably taking about this deal on a PATA Seagate
But that same WD 2500JD drive can be had for $98 new.
Or the SATA 3G WD2500KS with the 16MB cache for $104.99
Or a Seagate 300GB SATA II for $113.95
http://www.hardforum.com/showthread.php?t=1012459
Great deal at Monarch on the WD2500JD but I don't know if I would buy a refurb HD? And I am in the market for cheap storage.....
I would have bought that refurb X850XT though... ;)
Wow. I would have bought one of these "just because"
You're prob right about the refurb hd. But if one was to only use it for like storage of newsgroups. Not that big a deal for those kinds of storage. hehe. Easy come, easy go. I'm considering the 70.00 hd.
ZMAN
monarch cancelled my order, said they were out of stock. offered to replace the order with a 6800gs agp, $205. for reference, i completed my order at 4:34pm...basically as fast as i could fill in my name and info.
wow... I would have jumped all over that.... The best AGP card you can get for 125..... wow
I have to highly recommend monarch here. they accomodated me with a good discount on another fast AGP card (not the 6800gs) when i called them about the order cancellation.
