I've been throwing this idea around in my head...decided to throw it on here to see what ya'll would think.
What if, you ducted the intake/exhaust of your PC into the wall cavities of your home?
Obviously there is the fact that you'd be cutting at least 1 120mm hole into the side of your wall but if you never plan to move the room layout around, it would be an easy patch for when you move out.
But here is what I was thinking, for those of us that have a 120mm exhaust (or in my case intake) you could get some flexible tubing to run from the wall to the back of the computer and then cut a hole in your basement/crawl space floor where the wall cavity is for the air to be drawn from....though crawl space would be a less suitable location and you'd definately want to be an air filter of some sort over it.
Then you could also do the same for the hot air exhaust except go up to the attic and cut the hole there so the heat would naturally rise up into the attic instead of dumping into your room. You could even install a trap door that opens when the fans turn on.
On the subject of fans, it would also probably be possible to wire a 10-15 foot double-wire strand to molex connectors and connect a high speed fan to it up in attic so that, 1. you dont have that massive noise of a fan directly beside you and 2. it would help pull the air through the tube.
These are just ideas floating around in my head....now [H] community....someone do it lol or tell me what's wrong/right about it (Other then OMG YOUR CUTTING HOLES IN YOUR WALLS NO NO NO)
