Red Alert #
SGD
What gives the box mentions that the game supports Windows XP and Vista32. Were is 64 bit? Aren't most people installing Vista 64 since there is a memory cap with 32bit.
I'm sure you can play it on 64 bit, it's just that those are the versions of windows that the majority of the public has. EPIC FAIL with the title, lol.
Yeah, seriously. What the hell kinda thread name is that? Oh, it's even a typo... Red Alert 3.. Red Alert # :p
Anyone running a 64bit OS should know weather or not a 32bit app will run. if your running 64bit Vista then chances are you know it will run. So no need to mention it on the box.
I see his point since it specifically says "Windows XP SP2, Windows Vista (32-bit)"
I reason that I mentioned this is I was on the beta team and the game would not work under Vista 64. I was even told that at this point the game does not work with 64 bit. I figured that they decided to stay that course for what ever reason.
I have the game installed on vista x64 home premium as we speak. No problems at all. The auto downloader for the patch hung a few times but eventually installed successfully. Just because it doesnt state specifically x64 doesnt mean it wont run, it just means that if you have an issue they more than likely will only provide you with limited support. Same thing goes for installing games on laptops. If you read most game requirements concerning mobile video cards it says "mobile cards may work but are not supported", same scenario.
