Since there's not a general help section, I'm posting here hoping to get some help.
I've not been in this situation before, so it's new to me.
I was given an older Dell Celeron system that I believe has a bad power supply, but there's a proprietary atx pin connector so no way for me to test with any of my spare supplies (anyone know any adapters - looks to be four or six pins smaller, same shape, than my 780i connector). Since I can't get power to the machine for now, what's the best way to try to recover some documents and pictures from the old drive pressuming it works?
TIA
While I'm here, I would like to use this hard drive after I've done a scan and reformatted, in one of my other pcs, that has an 80gb wd with a finicky power connector. With that in mind, is it possible for me to make some sort of image on the new hdd, exactly what the old drive had... so basically, I would swap the drives out and keep truckin. Reason I ask is because the other pc is about four years old (XP2800+) and it that time including moving to college and back, I've managed to lose my XP Home cd (atleast I was smart enough to write the key code on the inside of one of the panels heh).
TIA
