Recover data from partially corrupted HDD
eggrock
I have a 250Gb WD Caviar HDD that I'm trying to recover data from. I don't think this will be too difficult but I don't know what utility to look for--please pardon my data recovery noobishness. ;)
The symptoms are:
- Windows does not see the drive at all.
- WD Lifeguard Tools (run from Windows) doesn't see the drive. I haven't tried booting to the WD tools CD yet.
- BIOS recognizes the drive (including the model #) after a delay of around a minute.
- One of the Ultimate Boot CDs disk checking apps. sees the drive but can't determine the drive letter. (There's a 'check all' option in the utility that I haven't tried yet.)
If there's a utility that can reset the drive letter and whatever else is associate with it? If so I think recovery is as simple as doing that and then running chkdsk to fix errors. Can one of the data recovery apps. do that?
if the bios slowly recognizes the drive then it sounds like the drive is failling. I would use a linux live cd to see if you can mount the data and if so copy whatever you can to another drive, then run a chkdisk and see if you can access it in windows
Sounds like a plan, thanks. Any recommendations? UBCD (Linux flavor) is the obvious choice. SystemRescueCD?
Well this might not work out so well. I ran one of the scans (check for bad sectors only) and in ~12 hours it only checked ~55k sectors out of 488,000,000. Over 18k were bad. Dammit.
