Recommended mobo for media computer
Leo123
Hi all,
I am building an HTPC, which has got to be quiet and efficient. It will not be used for gaming, but has to be capable of producing full 1080p picture quality/playing blu-ray.
The computer is going to be plugged into my tv in the lounge and I eventually intend to wire cat6 all over my house, via a gigabyte router - so I can stream live or recorded tv to two other televisions via media extenders.
I also have a sat dish with twin lnb and an external aerial, so the computer has got to be capable (in the unlikely event) of recording two channels, whilst allowing live tv to be watched in the living room as well as streaming a recording to one of the media extenders all at the same time - this will not happen very often, but probably will happen eventually.
The computer is going to be used as a replacement for my DVR, so it needs to come out of sleep mode properly and come on automatically to record and return to S3 afterwards.
My specs are this
Mobo: ?? - Nvidia board with onboard graphics and e-sata (decided against a 785G board, due to current problems with ATI graphics drivers and BBC HD)
CPU: Athlon II X2 240
Modular PSU: Corsair 450 HX
HDD: F3 1TB Spinpoint (Paritioned) - or possibly 1TB Eco Green, but possibly 5,400 rpm too slow for mutliple streams?
Operating System: Windows 7 32-bit, using MCE as the front end
Case: Antec Fusion Remote Max
Optical Drive: LG Blu-Ray
RAM: 2x2GB of RAM (brand and speed undecided)
TV Tuner card: Black Gold BGT3595 (apparently coming out next month)
Can anyone recommend an Nvidie mobo with decent onboard graphics that would be fit for my purposes?
Thanks
Thanks v much. Nice mobo.
Do you think there is any point in going for a 9-Series board - what would be the advantages of this over the 8300 as suggested? (apart from price).
Also, my case can take a full size ATX board - do you think I should consider one of these? I know I only need a single PCI-E card for the tuner, but would a bigger board mean things are slightly more spread out and thus cooler/slightly better for air flow?
Thx
A
Well first, you would have to go with an Intel CPU as the 9300/9400 chipsets are for Intel CPUs only. Second, there's really no advantage with going with the 9300/9400 chipsets unless you already have a socket 775 CPU on hand.
Not really. There's really no major benefit with going with a ATX mobo besides the expansion slots when it comes to HTPCs.
Phew - thanks for that. Almost got an intel board with an AMD CPU!
Would you second gwarren007's choice on the ASUS M3N78-EM? This a board that I have good things about before.
I'd second it.
I used an ASUS M3N78-VM for my HTPC, running MythBuntu, and it's working great. I had an issue with overscanning on my TV due to the linux video driver, but I figured out how to work around it. Otherwise everything's good.
